Sold 15" tc3000 160+shipping
perfecxionX
1. Product: 15" TC-3000 quad 2ohm
2. Specs:
• 160 Newtons2/watt Motor Force
• 1000 Watts Continuous Power
• 3" Anodized Aluminum Voice Coil
• Single Dish Titanium Cone
• High Excursion Tall NBR Surround
• 215 Ounce Magnet Structure
• Anti Flux Modulation Shorting Ring
• 30mm XMax
• 10" Diameter Suspension System
• Custom Cast Aluminum Frame
• Quick-Detach Top Assembly
TC Sounds (TC-3000)
3. Description/Condition: The sub works perfectly, but i would probably give it a 6/10 on cosmetics. Aside from one small dent (see pictures), the cone is perfect. You can see that the motor has a little corrosion on the bottom, and no longer has the bright shine that it did brand new. There are a few small scratches on the basket, and a bit of cracking where one of the screws attaches the basket to the motor. Also 3 of the 4 speaker terminals are loose from the basket, meaning that they cracked and are not really rigidly attached. They dont rattle or anything like that. You can see i tried to show this in the last 2 pictures (notice the terminal is not pointing directly down). (notice references in sig)
4. Price: : SOLD
5. Pictures:
perfecxionX
perfecxionX
indianapolis
perfecxionX
