15" Nightshade vs 9512G
Redgp
I have a 9512G and am considering a nightshade 15". My amp is an autotek mm4000.1 it puts out 4k at 2ohms. The 9512 is dual 1.5 and the nighshade is Dual 2. So neither one will bring it down to 2 ohms. I just want to know which woofer will sound and perform better in my hatchback mustang. I have about 3 cu ft to work with after displacement and port.
you don't even have enough room for a nice ported box for a 15, this is an easy decision
3 cu ft is the recommended space for a sundown nightshade //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I thought that 4000.1D was 4k@1 ohm?
If you get talked out of using that DD sub, I'm sure you will have no problem selling it.
did you factor in bracing and double-baffle into your displacements??? if you didn't you could be well under that 3cu.ft. number
See that might work then. thight squeeze in the back but i think i can make it work.
Autotek MM4000.1D
← home
Mean Machine
2 X 900 RMS @ 4 Ohms
2 X 1400 RMS @ 2 Ohms
2 X 2000 RMS @ 1 Ohm
1 X 4000 RMS @ 2 Ohms
I dont know why but i dont see DD's moving a lot here lately. I seen the 9512 on sale here and they just dont go. Only ones i see moving are selling real cheap
Redgp
Redgp
Tucson, AZ
cdimic25
