Sold 15" chrome plated Nuke
hoss
imma genius. so **** it!
up for grabs is a 15" Ground Zero Nuke, witha Chrome plated basket/motor. when i purchased this woofer, the original dustcap had been damaged and could not be repaired. i replaced the dustcap with a substitute, it was slightly heavier than the original, however, the tested T/S were not far off of the original. they were tested to be as follows:
Re: 6.5 Ohms (coils in series)
Fs: 29.9 Hz
Qm: 9.1
Qe: .38
Qt: .37
BL: 35.5 (which is very good/high BTW - should help
with the sale)
Le: 8.5 mH
Sd: 132.7 sq. in.
Vas: 73.3 liters
Mms: 397 g
SPL: 88.8 dB 1W/1M
woofer features dual 4 ohm coils, and it gets NASTY loud.
asking $350, will consider trades, but im not looking for anything in particular.
as stated, the dustcap has been replaced. and those specs are the tested results, after the dustcap replacement. as you can see, it didnt change much at all, except for the nicely reduced Fs //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif .
the basket does have some minor scratches, but as the pics show, nothing major.
great seller and great sub, just remember to wrap this one in some bubble wrap //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif ;)
hehe. duly noted. i learned my lesson. thanks for the bump //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
p.s.--that amp is still callin your name //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hoss
hoss
inside icetee, while he is inside seths sister
hoss
