Sold 15" and 12" XXX SNAILSHELL BOXES
Chriscivic
Registered User
I have built two snailshell boxes so far and both have turned out great, they look better than any other "fakeshells" i have seen. i sold one to "silver02alty" on sd and built another for someone local. these are designed for the xxx but work with lots of subs. i can make one for the 15 or the 12. anyways i am selling the snailshell boxes. here is some pics of the one i did for silver 02 alty:
$180 for the 15" snailshell
$150 for the 12" snailshell
e-mail me or aim at chris1424882@aol.com
from what i have read, it is tuned to a diff. frequency in each port, i copied this:
"The idea behind the box is great SQ with Low Loud Bass. Under the ideas I have read and been told, the idea of the snailshell is genius, by using different tuning levels internally the box gives it a unique sound, like for example the first port inside the box of 45 hz is for bass and the last port of 30 hz is for SQ..averages around 37 hz...but you get the bass and SQ you want. I have 2 RE XXX 15' quad 1 ohm subs being ran by two Kicker KX2500.1 amps. I had them in a custom built Subzero Ported enclosure. 8.0 ft at 35 hz and it was loud. I bought "ONE" SnailShell and ran one XXX in it. The SnailShell with the XXX was as loud as the subzone box with both XXX in it, and the SQ was twice that of the subzero box. I am running two SnailShells now and for an everyday bass vehicle i can flex my windshield and have the SQ I want."
Sorry to drop a bomb, but.
Anyone who is capable of building one I'll give the plans to for the XXX 12 and 15.If you can have someone design a custom one for your sub it'll turn out better than a "generic" box.
For the record, the low end of the p4s ss's are quite sad.Anything above 40hz will do good.These boxes are tuned pretty high actually.
I'm sorry to drop this on you but you're acting like these are end all be all of boxes, quite frankly compared to other "advanced" designs these aren't all that great.And I have seen better work than yours, esp. on these types of boxes.......
Free bump none the less.Not trying to post dump but I'm pointing some things out.l
Chriscivic
Registered User
Chriscivic
Upstate,SC
Pyro_By_Nature
