13.9 or 15 volts?
Justinh722
I'm doing a build for a buddy with two 12 inch Orion HCCA black coil series subs, a Skar Audio 4500.1 amp, 2 runs of knukonceptz 0 gauge from red top battery to 2 large yellow tops in the trunk. He had a 320 amp custom alternator built by excessive amperage that I installed last night. Only problem Is the alternator is charging at 13.9. I found out the voltage in the car is regulated by the ECU.
I called EA up and he said he would put a regulator in the alternator for free so it could run about 15 volts. Just wondering if he would benefit from the 1.1 volts. Any suggestions? I know 1 volt could prob yield a good 400 watts or more I'm assuming.
Justinh722
Justinh722
Mason City, Iowa
adulbrich
