12" that will handle 2-3kw daily.....
Mach 5 SPL, Sundown Nightshade, RE MT, AQ HDC3. All those will handle to power with no problem and there are more that can handle that power you just have to know what you are doing.
IMO the most listenable one out of the bunch listed is going to be the Nightshade. It will also handle the power and it's built like a tank.
can you give me any info on the nightshade? all it says on the sundown site is text.....thanks (specifically what size box ported?)
Quite a bit of info over on my forum:
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=16102
* T/S Specs
Boxes for the 15s range from 2 - 3 cubes daily. Larger for high efficiency SPL burp boxes.
Boxes for the 12s range from 1.5 - 2.5 cubes for daily. Larger for high efficiency SPL burp boxes.
Some installs and results:
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=17179
http://www.stevemeadedesigns.com/board/index.php?showtopic=21709
http://www.stevemeadedesigns.com/board/index.php?showtopic=19751
so it sounds like the mach 5, AQ, BTL, and nightshade will all work in a 2.5-3 cube box correct? now i just need to decide between these.....
edit: these will not be for burps //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
5.3bowtie
5.3bowtie
Detroit, MI
5.3bowtie
