Sold 12" Re Sx
NightDrifter05
I just purchased a Digital Designs 3512 so I am going to try to get rid of my 12" SX Dual 2. It has about 10-15 hours of playtime on it and is the newer model. It was acquired in a trade from Team PSI. This was a great sub, I had it being ran by a modded MTX 1501D. I want to get $130 SHIPPED and that's a firm price. I am open to trades as well. Trades wise I would like to find a MTX Thunder 4 channel or big 2 channel. I am mainly looking for the black and chrome versions to match my sub amp. I would also be interested in 4x6's, 5x7's, and 5.25 components. Would also be interested in batteries, 1/0 wiring, a LCD monitor that has a DVI plug and is HDCP compliant...pretty much anything so just PM or post what you have.
I will get better pics per request but those are all I have for now.
i've always just had random pos subs such as sony, cheap pioneers. so excuse my newbness about this sub lol. what im jw is the rms/max watts it has. i can't seem to find it on google
SX12-D2 (SX.12.D2/SX12D2) Features:
* Dual Composite 2-piece Cone
* Rubbertek Foam Surround
* Cast Aluminum Basket
* Tork-Tite Terminal
* 3 ” 8-layer Aluminum Voice Coil
* FEA Optimized Motor Structure
* Triple Stack Magnets
* Progressive Spiders
* Wrap around Rubber Gasket
SX12-D2 (SX.12.D2/SX12D2) Dimensions:
* SX12 12" Dual 2ohm Subwoofer
* Mounting Depth - 6.5”
* Mounting Hole Diameter - 11”
* Overall Diameter - 12.5”
* Bolt Hole Circle - 11.75”
* Motor Width - 6.5”
* Motor Depth - 3.25”
* Basket Depth - 3.25”
* Displacement - 0.16 cu. ft.
* Weight - 24 lbs.
SX12-D2 (SX.12.D2/SX12D2) T/S Parameters:
* Electrical Q Value -Qes: 0.32
* Mechanical Q Value -Qms: 4.4
* Total Speaker Q Value -Qts: 0.30
* Free Air Resonance -Fs: 30.6 Hz
* Equivalent Compliance -Vas: 47.6 liters
* One-Way, Linear Excursion -Xmax: 22 mm
* Efficiency -SPL 1W/1m: 88.1 dB SPL
* Effective Piston Area -Sd: 480 cm^2
* DC Resistance -Re: 1.9 ohm
* Nominal Impedance -Znom: Dual 2 ohm
* Thermal Power Handling -Pe: 1000 W
* Force Factor -Bl: 21
SX12-D2 (SX.12.D2/SX12D2) Recommended Enclosures:
* Ported Compact: 1.5cf tuned @ 35Hz
* Ported Optimal: 2.0cf tuned @ 33Hz
and for any others who come into this thread to view it the price is $150 shipped as long as you're within the continental US. I want to sale the sub but I'm not that hard up to sale it for a crazy low price...
NightDrifter05
NightDrifter05
Lake Gaston, NC
BreakMyWallet
