100GB Hard Drive
macq32
For sale I have a new OWC Mercury External Hard Drive. All needed wiring included, plus the case that came with it. First 7200rpm drive that doesn't require an additional power source (no DC/outlet required, plug and play like a flash drive). It is a 100gb drive, looking for $80, all expenses included. Bought a few weeks ago with intent to hook it up to my Kenwood head unit, apparently the Kenwoods operating system isn't compatible with this. Plugged it in to my computer, put a cd on it, plugged it into my HU. That's the only use its seen. 10/10 and 10/10 for this.
"High-Performance 2.5” 7200RPM drives with 16MB data buffer gives you maximum storage in an ultra-portable, totally bus powered design. Stylishly engineered in a sleek, impact-resistant acrylic enclosure, the incorporates shock-isolation technology to give maximum protection for your precious data inside. The Mercury is a true must-have for users like you who are seeking High-Performance and Highly Reliable storage weighing less than 11 ounces and that is small enough to fit in your shirt pocket."
Sweet drive, complete with 800/400 firmware connections, usb 2.0 and an optional DC power.
free bump... also fyi some players will not recognize hd's or ipods bigger than 80 gigs. i had an in dash dvd unit that would not play my 80 gg ipod and when i did research this is what i found out. good luck with the sale...
thanks man, ill have to call kenwood to check this out first then
with this harddrive I will throw any cd's you want on it. Excluding g unit, lil wayne and other garbage
No to post dump, OP. But it's not the first... it might be the first manufactured. I used to modify all of my old external cases to power VIA USB.
yea i understand that, been going on for years. but yes this is the first drive manufactured specifically to run at 7200rpm while only requiring a power via bus.
and this is as good as new in every way and less than half of the price:cool:
macq32
macq32
Charleston, SC
macq32
