1000C4 vs ONX4.125 vs ZXI-150.4
ctmaudi
Looks like Im going with the DCON after all. Going to get a 4 channel that can give 100 to my comps with some headroom, and bridge the rears for about 350-400rms. Some headroom would be nice in case I decide to upgrade or if I happen to find another sub deal before I order. $200 limit.
Crescendo 1000C4 $195 shipped
125 x 4 @ 4
250 x 4 @ 2
500 x 2 @ 4
rated @ 13.8v
3x30 amp fuses, HPF 50hz-1kHz 18db octave (no subsonic use, not high enough to cross for active if I wanted to later on), LPF 30hz-250hz 18db octave
MB Quart ONX4.125 $155 shipped
125 x 4 @ 4
250 x 4 @ 2
500 x 2 @ 4
rated @ ??
3x40 amp fuses, HPF 60hz-13khz 24db octave (no subsonic use, high enough to cross for active if I wanted to later on), LPF 30hz-250hz 24db octave
Hifonics ZXI-150.4 $200 shipped
150 x 4 @ 4
300 x 4 @ 2
600 x 2 @ 4
rated @ 14.4v
3x40 amp fuese, HPF 10hz-15khz 12db octave (can be used as subsonic filter, high enough to cross for active if I wanted to later on), LPF 30hz-150hz 12db octave
Which is the best bang for buck? Im sure the Crescendo is the highest quality one, but is it worth sacraficing the features of the other two, and paying $40 more then the MBQuart?
If the new Quart 4ch is anything like the old 4125, the Crescendo will put out way more power. I did a direct swap from the DSC4125 to the 1000C4 and it did so much more power and stayed infinitely cooler.
i am thoroughly impressed with the 1000c4 i installed in my uncle's truck. its running 2 channel mode to (2) Selenium 6w4p's and a single Selenium ST350 in each door crossed over with dayton pro crossovers and that ish is soooooooooo loud and clear as hell too. AWESOME AMP!! i really don't think you will do better for the price.
ctmaudi
ctmaudi
Akron, OH
ctmaudi
