1 0hm wireing
is it a one ohm stable amp? i'm not too sure about kicker amps... to wire to one ohm do this:
Well im curious because on kicker subs one positive terminal has a white dot on it and one doesnt. Same with negative
the dots represent the same voice coil. so the pos and neg with the dots are voice coil 1, the ones without the dots are voice coil 2.
as far as amp settings that's dependent on car, box, source unit, wiring, amplifier, etc. so we can't really tell you how to set your amp.
So i put a wire from a positive on one voice coil and a wire on the negative for the other voice coil both leading to the negative and posite terminals on the amp?
You can't get to 1000 rms with your dual 2 ohm sub on this amp, the lowest you can go is 4 ohms, hence, 550 watts rms, wired like the diagram below.
A dual 4 ohm sub will take you down to 2 ohms, hence, 1000 watts.
tnota
tnota
louisiana
Brian10962001
