03 Quad Coil 12" RE XXX
ace_800
3rd owner, bought off Subzero about 3 months ago. Original parts, never been abused. Quad 1.6 coils. I've been running it off my exile 2400.1 in the box in my sig. Has been handling 2k daily. More pics up tomorrow. Still in use until next week. No damage, minor scuff.
Top pic is mine, bottom 2 are the other XXX that subzero was selling for reference. Mine is the same basket and motor, though the basket is silver not painted black. Also mine is a quad 1.6 coil not a Dual coil.
Specs I've found
Re: 12'' Resonant Engineering XXX sub, 2003
RE AUDIO - Woofers
Enclosure Recommendations
12" Compact Optimal
Sealed: 0.85 1.1
Ported: 1.7@35Hz 2.2@34Hz
T/S Parameters
12"
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 3.29
Total Speaker Q Value -Qts: 0.404
Free Air Resonance -Fs: 21.00 Hz
Equivalent Compliance -Vas: 74.0 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 83.76 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 or 4 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
Product Dimensions
12"
Mounting Depth - 12.75 inch
Mounting Hole Diameter - 11.5 inch
Overall Diameter - 13 inch
Bolt Hole Circle - 12.25 inch
Motor Width - 10.5 inch
Motor Depth - 5 inch
Basket Depth - 7.75 inch
Displacement - 0.24 cu. ft.
Weight - 72 lbs.
$350+shipping obo
ace_800
ace_800
Okinawa, Japan
ace_800
