Current events discussion
Yeah no shit? Just saying he spent double what Trump did and it still looked like shit, I wouldn't expect you to acknowledge that the left has you so brainwashed that you tardbots go ape shit over shit Trump does when your dear leaders did the same or worse.
That's fair. Show us some evidence of how the reflecting pool turned to sh*t within days of the work being completed under Obama.
Given how some idiots here think the whole algae thing was faked and the pool has been perfect the whole time, proof is not an unreasonable ask.
You have never heard of liquid liner? Then STFU and go do some homework before you try and come argue about some shit you didn't even know exists..
If you're talking polyurea, and you actually believe it can just be cut and peeled off a few days after application, then you need to do your homework and learn about how sh*t actually works.
A roll of pond liner LOL..
Are you ******** retarded Rawb? You eat paint chips for dinner growing up?
LOL.. You probably look like that ******** caveman from the insurance commercial you ******** baphoon LOL..
A liner goes in a pool. A spray/or rolled on coating goes in a 7 million gallon basin.
Yeah, you wouldn't know it because you have your head so far up your *** plus the "news" you watch will never speak of it, but a lot of the shit they tell you is lies.. This can be proven very easy but when presented with facts you lefties break down, lash out, become violent, and all kinds of crazy.
And yet, you provide no proof. "Easy", huh?
Quit the filibustering and show us a pic of one of your concrete ponds you have extensive maintenance experience maintaining, and name the product you coat them with.
The product that can be cut and peeled up after application and refill.
The Santa Ynez reservoir is a negative impact to the to fires when it's empty. Again, Name 3 reasons why the reservoir was built. Come on old man! Tell us! You can't! If you did, then you would have to admit one reason, it was built, was to fight fires.
You can repeat that a thousand times, but there is nothing you can offer to prove it, and there is a ton of info to refute it.
Quit the bullsh*t tapdancing, and provide proof that the Sant Ynez being empty caused the fire damage to be worse. Explain to us how you (the guy who thinks there is one water tower to feed LA and the Palisades) are correct, but all the experts are incorrect.
Idiot that you are, you even provided details of the water feed capacity in the LA system that proves the status of the Santa Ynez had no relevance to the fires. You're just to lost in that empty cavern of a brain to even know it.
Ironic.
"Water can be pumped into the pressure tanks from Santa Ynez at a flow rate of 5,500 gallons per minute. As stated above, the main water line has a maximum capacity of 37,000 gallons per minute pumped to thefire area. Santa Ynez could have only supplemented an additional 5,500 gallons per minute to the system or an increase of 15 percent to that flow rate, resulting in a total area flow rate of 42,500 gallons per minute between the main pipe and the pressure tank supplemental water. Therefore, even if Santa Ynez was full, once the flow rate demanded by use of fire hydrants and leakage from destroyed homes exceeded this maximum flow rate of 42,500 gallons per minute into the system, the hydrants could not have maintained pressure."
You're an old senile man living in a trailer park in Duluth, Minnesota. YOU have no knowledge of life in California. So, go back to your democrat shrine and tell them how good of a boy you are being for lying for them.
Not a single word of relevance to support your bullsh*t stories, and refute the fact that you have absolutely no understanding of how things work in your state, or any other.
Then again, it's common for you right-wingers to avoid the actual issue at hand, and just dance off to some other bullshit. Just like your Demented Orange Idiot leader.
So instead of bullsh*tting, show us the analysis and report YOU have prepared, detailing why the Santa Ynez being empty was the catalyst for the severity of the fires and the subsequent damage.
Something, something, "indoctrinating our kids".
Stories of ******, ************, sacrificing children, murder, war, pedophelia. All good and a mandatory book because it makes "god" happy.
The hypocrisy of the right is fu**ing insane.
Remember kids, Rob is the resident expert on literally everything. Furthermore, if you do not use his terminology then you will always be wrong.
Rhino 406 primer was used first then Rhino Pipeliner 5000 in American Flag Blue. It is a Polyurea resin coating use to waterproof. The reason the cry baby liberals are able to cut it and remove parts of it are because the primer takes a long time to penetrate the concrete and cure and the Pipeliner flashes in seconds and cures rapidly. Installation issues DO NOT forgive cowcunt, ***** *** libtards for breaking the law and vandalizing the pool. Brainless, Godless Communist heathens who care for nothing except their own villainy.
So Trump forgot to account for libtard vandals and should have the reflecting pool under 24/7 armed guard. I knew this was all Trump's fault. Orange Man Bad.
lol at idiots who prove that Demented Donzo screwed up with yet another grift meant to benefit a friend, when they think they are defending his lies.
Properly applied polyurea is incredibly difficult to remove from a surface. You don't just cut and peel like it's a vinyl liner of a swimming pool.
"Typically applied thick, polyurea and rubber coatings are notoriously hard to remove. Regular abrasive blasting methods are rarely effective in removing these coatings. Abrasives like garnet and coal slag bounce off these surfaces causing them to heat and become gum-like with little removal."
"Polyurea is an elastomer, meaning it has rubber-like qualities. Originally developed for industrial applications—like lining the inside of heavy-duty pipes and creating waterproof membranes for commercial roofs—polyurea is built to withstand extreme punishment"
Yeah, go slice the bed of that pickup truck with the spray-on coating, and simply peel off a big chunk with your fingers. FROM THE SMOOTH METAL. Tell us all how easily you peel up those big chunks. Now, do it from concrete, where the rubberized goop has seeped into the porous surface before curing.
Good luck.
Trump caused the Strait of Hormuz to be closed by getting us into an unnecessary war that achieved nothing. Four months later, oil is 27% more expensive, and gas is 34% more expensive. Inflation is up from 2.4% to 4.2%.
All hail Diapered Dear Leader Dozing Donnie! Bigger numbers are better! Winning!
*Brought to you by the same types of idiots who thought a 1/4lb burger was bigger than a 1/3lb burger.
One company advised the pool things as not doable in Trumps time frame so they passed on it then the other company who should have told Trump the same thing took the contract. What the second company should have done was told the administration that the primer needs considerably longer to cure than the liner and needs to be fully cured before applying the liner. Trump is just the guy with the idea and time frame. The professionals should have advised him. One company did for sure then the other company with different products may not have informed him but for sure took the multi-million dollar contract.
I blame Atlantic Industrial Coatings for the improper application and the mentally defective liberals for the vandalism.
Yet the Diapered One is completely obsessed with it, and will do and say anything possible to deny it was a failed experiment, and a waste of $30 million.
God damn that guy for being proud to be American and wanting America to be beautiful. God damn Trump for that!!!
"Cut the liner"? Are you effing kidding me? Go paint your concrete parking pad. Let it dry for an hour. Try to "cut" a gash in the paint. Let us know how it goes.
The Rhino liner is not paint. You know it isn't paint. Stop trying to use sarcasm to talk down to people.
The crazy part is that his bootlickers believe him, and will repeat the same stupidity.
When you can see people physically remove pieces of liner with your own eyes that is not "believing him". That is knowing what you just saw is reality and you don't have to wait for CNN to tell you to think something else. Like that moron on the bike in the other video who was literally at the pool, could see it was looking good and said he would rather take CNN's take on the pool looking the worst it has ever looked.
You people are the epitome of failed abortions.
It's tragically comedic when right-wingers only prove Demented Donnie's incompetence when they try to defend him.
Professionals said a job could not be done, but Dipshit Donzo is much smarter and "knows a guy", and gives said guy a no-bid contract.
The job is an utter failure, but Diapered Dipshit has no culpability at all, because he just wants to make America great "again".
JFC, right-wingers would eat the feces from his sphincter if he claimed he was soft-serve machine.
It's truly pathetic that far left cock suckers think sarcasm proves their point and makes people look stupid.
The other company used a completely different product all together. Obviously they said the job could be done because they took the contract. Explain how Trumps is to blame for having an idea and giving a timeline. Explain that Rob.
Jimi77
Premium Member
CarAudio.com VIP
Jimi77
Denver, CO
deez283
ThxOne
    Jun 27, 2026
ThxOne
    Jun 27, 2026
