Replaced Blown Fuses, Amp Won't Turn On
  • 2
sbunce5
So I've done a lot of searching but I can't find anything that would tell me why my amp won't turn on after replacing the blown fuses.
I received a new amp and was hooking it up and made the mistake of doing the negative wire first and then the ground. When I touched the ground wire against the terminal, both fuses blew. So I replaced them, hooked up the ground wire first, then the negative, and I can't get any power to the amp. No lights or anything. Any ideas?
More than likely from my 20+ years of experience.. Sounds like you blew the power supply in that amplifier. You will either need to get it repaired or replace that amplifier with a different one.Replacing the fuses will do nothing for that amp until its repaired
Is there a way to tell that the power supply has been blown for sure? I don't see anything that looks like it's been burnt or any black anywhere.
You can take it to an Audio shop and have it tested?. You swapped polarity and blown the power supply on the board.Your warranty will be void more than likely after inspection. .
Its Internal on the main board.you will not see it from the outside.Does it smell like rotten Eggs or Baked plastics/burnt?
You can always open it up and view it for yourself.You will not get a warranty replacement on it anyways after they do an inspection on it, and youll waste your money shipping it in.
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
JUST BRAINSTORMING HERE: Yeah, you might also want to compare the backs of both. (You just said "android radio", is this an amazon special...
13
Super easy and Cheap..Ill bet your father or Gramps can solder it pretty easily?? You Tube is your friend too. As well as H.freight /Lowes/or...
14
I am going to have to pull it out of the dash and have a look again to see if the wires are correct. I sent over this with a pro shop many times...
sbunce5
sbunce5
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
