Thanks on the complements......
Its a 10" dimond audio hex series sub (macdaddy) with around 360watts of power form the rear channels of the amp.
The port is tuned to 28 Hz and is around 34" long alone the height of the box. The enclosure is actually slanted in the back to get the most out of the space behind the seats and totals 2.8cuft.
And that mold around the port is just some rubber molding I found at homedepot and cut off the edge of it...then just siliconed it to the outside.
Check back in like a week or soo, because Im getting rid of the current enclosure and glassing a sealed one where the med/flare compartments is.
Also adding a diamond D7054 amp and a axa 400.2 for the sub.
wow 34" long to get 28hz hmmmm seems a bit long to me since the port looks like its an inch or so in diameter. but i'm retarded so what do i know. how does it sound?
