Wiring two subs
Those amps are 330w RMS x 1 @ 4ohms. (and 600wRMS x 1 @ 2 ohms) So unless you already have these sitting in your closet, and those subs are 250-300w RMS @ 4ohms each, (or 600w rms @ 2ohm) I wouldn't. I wouldn't buy two amps to do this when you could just run one amp, and a little more speaker wire.
If they are both 4 ohm, then an amp that will double there RMS @ 2 ohm is a better option.
If they are both 2 ohm, then an amp that will double there RMS @ 1 ohm is a better option.
Thank you
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Sell the dual 2 and get another dual 4.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
411
hossk24
hossk24
Three Forks Montana
audiobaun
    May 31, 2024
    May 24, 2024
