Wiring two subs
Those amps are 330w RMS x 1 @ 4ohms. (and 600wRMS x 1 @ 2 ohms) So unless you already have these sitting in your closet, and those subs are 250-300w RMS @ 4ohms each, (or 600w rms @ 2ohm) I wouldn't. I wouldn't buy two amps to do this when you could just run one amp, and a little more speaker wire.
If they are both 4 ohm, then an amp that will double there RMS @ 2 ohm is a better option.
If they are both 2 ohm, then an amp that will double there RMS @ 1 ohm is a better option.
Thank you
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Sell the dual 2 and get another dual 4.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
183
hossk24
hossk24
Three Forks Montana
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
