Wiring Options for Setup
gsxkod
6
Omaha
Any recommendation for this setup? I need a smaller unit as space is very limited. I could do two amps as well as long as they are small. This is going in a cooler setup.
Nvx mvpa4 tiny 4ch for $199 50w x 2 at 4ohm to power the speakers and 150w for the sub when you bridge the 3&4 channels to 4ohm. The Manuel will show you how to do this but basically you put the + from the sub to the + of the 3ch and the sub - to the 4ch -.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
250
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
654
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
678
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
677
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
577
gsxkod
gsxkod
Omaha
LosIsATool
