Wiring Help!? Question on Wire Brand & Question on How to Wire 4 Channel
  • 2
bgolightly82
Ok, so question 1. I currently have a Memphis 1/0 wire kit (super flexible!), its really nice wire (over $200 retail). But I am going to need much more 1/0 and 4 and 8. I was thinking about going with KnuKoncepts (not the Copper Clad Aluminum ****), which I hear is a pretty good wire and way cheaper than the memphis! So my question is, is the KnuKoncepts good enough that I should just buy it in bulk and use just that, then sell the Memphis? Or should I really just bite the $ and buy more Memphis? I'll be running about 3.5k for all. Think the KnuKoncepts is decent enough at that level?
Question 2. I have a set of ID 6.5 Comps, and a set of ID 6x9's (all are 4 ohm / 100 rms) with the Soundstream DTR4.500 (4 channel - 80x4 @ 4 / 125x4 @ 2). So I obviously want to run it at 2 ohms, but how do I wire it to speakers?
I looked at the wiring diagram for it in the manual, but they are just wired to each channel, which wouldn't that just be 4 ohms?
I'd keep the Memphis and run it to a distro black that can't be seen. Then just buy some Knu to run to your amps. That way you can't visually see the two different kinds of wire.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
531
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
929
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
978
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
bgolightly82
bgolightly82
Jackson, MI.
RAM_Designs
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
