Wiring 1980's sears cassette deck
  • 2
Nineteen ninety two
Usa
Not including speaker wires and ground.I need help matching to modern colors. 1980's sears owners manual=  R e d wire connect to the existing radio power wire or to fuse marked "radio" "ign" "fused" or "acc fused".  P i nk wire connect to a wire or fuse which is on regardless of the position of ignition key.Normally made to the cigarette lighter wire .Yellow wire=power antenna activating wire,12 volt +..Need matching to  the.Colors on scosche connector left are Orange=illumination/dimmer , dark  blue= power antenna,  Red=12 volt ignition/switched (12V+).This is going in an 85 elcamino.Previously had an kenwood cd player with the orange and blue taped off.
What are you asking exactly?
Old red to new red. (accessory/ignition wire)
Old pink to battery voltage, (12v/battery/hot wire)
Old yellow to new dark blue, (to make your antennae go up and down).
New Orange is to your dash illumination. (this will make your head unit dim with your dash lights). Not necessary to connect it. You can probably set the brightness on the head unit if you want to keep it steady. If its not on your harness, you would need to tap into the wire somewhere around the dimmer switch.
Thanks.I appreciate the help.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
240
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
643
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
670
666
574
Nineteen ninety two
Nineteen ninety two
Usa
Nineteen ninety two
Decebal
    Jun 10, 2024
