Will spiral upcut bit cut thru double baffle?
  • 2
jshak07
148.4 and climbing
1,389
louisville
Skil Router
Jasper Jig
1/4 collet
THe bit is long enough to cut thru 1.5 inch but heard its not best to cut both baffles at once? Is it cool to set the bit at a little over 1.5" and go at it or should I cut one baffle at a time?
If the plug matches, you just need to match the wires up. I re-made the harness for my audison amp, and the hardest part was getting the speaker...
Hi, I'm new here and the current car audio that I've had for a month is my first in my life, so I'm asking for your understanding 😉 I'm starting...
Problem resolved - Found a scrap Astra that was fitted with that same unit. Salvaged the Display and original plugs and wired it up on the dining...
jshak07
148.4 and climbing
jshak07
louisville
Slo_Ride
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
