Will my amp power these subs?
jreneberg
Hello, world.
I have access to a Clarion APX4360 amp (http://www.clarion.com/us/en/products/2007/audio/amplifiers/APX4360/us-en-product-pf_1165294846860.html) and I was wondering if it could power the subs I list below.
MTX Audio Terminator Series TNE212D 1,200-Watt Dual 12-Inch Sub Enclosure:
Amazon.com: MTX Audio Terminator Series TNE212D 1,200-Watt Dual 12-Inch Sub Enclosure: Car Electronics
Or
Pyramid BNPS102 10-Inch 1,000-Watt Dual-Bandpass System with Neon Accent Lighting:
http://www.amazon.com/Pyramid-BNPS102-000-Watt-Dual-Bandpass-Lighting/dp/B0007LCKMS/ref=lp_3009141_1_20?s=car&ie=UTF8&qid=1394466199&sr=1-20
Maybe neither of these subs are any good, but if you have any suggestions, I'm not so set on these two.
soundquebed would be a good place to start, check the classifieds, mant a deal has been found there. Your choices will only disappoint you. And like jeffdachef stated, might want to save a bit more and do it right the first time, so as not to put good money after bad.
Probably a safe bet that two "600W" continuous subs and "1200W" continuous amplifier from the same (reputable) company are designed to be a good...
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
Hopefully it is ok to post a "for sale" ad on here. If not, I apologize in advance. Fully serviced Earthquake PHD2 amp for sale. Asking $175...
jreneberg
jreneberg
Planet Earth
macsdad
