what size soldering wick should I use?
  • 3
You mean size of solder? I would use small strand rosin core. The big strand rosin core is hard to work with on small wires.
Wick is mostly used to remove solder and I have used it to fix plastic items that have a crack in them.
I had a remote starter installed yesterday and the tech soldered all the wires. It was quality work so I plan to do the same. I've never soldered before but will learn I just don't know what size to use.
Soldering just takes a little patience and practice.
I would try on some scrap wire first to learn on. A lot easier then having to cut wires shorter because of a bad connection while learning.
Also - you tube videos would help a lot to show you what you are looking for in a good connection.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
3K
It's a little overkill but hey... https://blackbrickaudio.com/collections/30-000w-amplifiers
11
mrpep
mrpep
chicago
lew-e
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
