What do i need to go for active Setup?
with the amps you have, you can pull off a 2 way front stage w/ a sub.
you'll either need an external cross over that can bandpass your mids, or an HU/processor that has a 3-way xover (high, bandpass, sub)
I have a Clarion MAX685BT HU, just got it. So buying a new one would not be an option for me.
Anyway I'm looking for a good Crossover and affordable.
I have a Clarion MAX685BT HU, just got it. So buying a new one would not be an option for me. :-(
You could ditch the 4 channel Phoenix Gold amp and get a Sundown 100.4. That will run you about 300+. Otherwise the best way is to get a new HU. I see what you have is an in dash DVD. I found one yesterday that was active capable but it was 1600 on eBay.
it's partly true. I would prefer not to get out of my listening position while tuning. I often notice things that needs changing WHILE driving (driving what I use my car for) and I'm able to make changes right there and then.
OK well I thought the same after watching the Audiofrog video of Andy explaining damping factor. I have to agree with you as well on the D class...
I was and still am a old school CD type of listener. Pio always had great CD players and fairly good TA/EQ options, got familiar and you know what...
39
148
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
110
455
zmcqdv
zmcqdv
Malaysia
zmcqdv
    May 16, 2024
    May 16, 2024
