What amp with two 10W3v3-4 SVC subs?
  • 2
Okay, as my introduction I am going to let everyone know that I am BRAND NEW to the car audio world. I am learning and absorbing all information I can. I recently bought 2 10W3V3-4 subwoofers for my 06 Ford Five-Hundred limited. I want to buy a JL amp with these but can't decide on a 500/1, 600/1 or 1000/1 to power these 2 subs. I want the subs to be pushed but not to the point they blow. Some help with a reason would be great! thanks!
Edit: I plan on wiring these parrallel which should bring it down to 2ohms I believe!
IMO, I would go with the 1000/1. I like to have extra head room and not have to run an amp as hard.
If you set the gains correctly and use common sense, you will not harm the subs....using any amp...
:confused:Okay sounds like I will go with that! Would you mind helping me with a box also? I was leaning towards a ported box from what I've researched. And I went to
Klaus Audio Custom made boxes, but unfortunately I dont understand half of the feild questions for the custom two 10'' ported box. If you wouldn't mind helping
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
165
6
395
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
702
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
511
DevonRayG
Banned
DevonRayG
Lee's Summit, MO
DevonRayG
