Wattage requirement for lithium 25ah charger?
  • 2
The01Trooper
CarAudio.com Newbie
I'm trying to figure out how small of a generator I can get away with for running the limitless lithium 25ah charger. How many watts does it require? Doesn't say on the website.
I want to take it to shows so I can charge between runs, but I have a problem of space. I'm running a 4th order in a isuzu trooper. So basically it would have to fit where a human would fit on the passenger side. 🤷‍♂️
Is this feasible? It's doing good numbers, but I'm at a severe disadvantage as I only have space for a single alternator. 320amp.
what ^ said. amp gain setting info, test tones are at the very bottom...
605
Which amp and which speakers? What crossover are you using? You may be fine so long as you never push the volume too hard.
12
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
7
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
9
The01Trooper
CarAudio.com Newbie
The01Trooper
East TN
The01Trooper
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
