Water getting to my door speakers.
  • 7
Top Notch
Yeah so the there are a couple of rusty metal shavings on the magnets of my front door speakers and the wires corroded right at the speaker terminal connections. So apparently I'm getting water through the window seals and down onto the back of the speakers. What would be the best/easiest way to seal the speakers from the elements? Is there some already built and available thing I could buy or am I stuck testing my (not so awesome) sheet metal skills?
97 Ford Expedition EB
Pioneer AVIC Z1 upgraded to Z3
Pioneer Rev 6.5 component front
Pioneer Rev 5.25 component rear
JL 8W3v3-4 sub
Phoenix Gold Tantrum 600.4 and 250.2 amps
Foam/Plastic speaker baffles are cheap to obtain,and will also enhance the sound of the speakers.May help ? Yet best to seal the leak though??
if you use the foam baffle, you need to cut out the bottom half.
as mentioned, water gets in all doors. that's why you have a plastic sheet in there, and why factory speakers have mounting cradles.
the water is running down the inside of the door metal. if you give the water a channel to go around, you can usually keep your speaker dry. you can achieve this with weatherstripping foam and/or deadener to create a lip around the top half of the opening.
3/4" closed cell weatherstripping foam:
BXT II over the seam and foam to increase the lip:
Fucking genius bro. //content.invisioncic.com/y282845/emoticons/imdaman.gif.bc6c552e19aa4ad8c47461144f40eb1a.gif
XTC baffles are fine, just recognize they are deeper than the window usually allows and you don't want to leave them enclosed. the speaker needs airspace and closed cell foam doesn't breathe. use the XTC baffle but cut out the bottom half and back as required for depth.
If it's still an issue, try this link. https://www.diymobileaudio.com/threads/protecting-door-speaker-from-water.81179/Personally, my latest...
That sound reminds me of when the headphone jack or RCAs are not fully seated.
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
744
Appreciate the input! I'll check out the calc site and see how it compares. I'm in the beginning stages of building the box. Unfortunately with...
988
Top Notch
Top Notch
New Albany, PA
Top Notch
chillin
    Jun 14, 2024
