The bassmachine flexing on less then half tilt.
I think i've asked before but for highs.. you're using those 2" drivers I think? The tangbands? or do you have something else as well?
Love the flex.
Love the flex.
I have 4 2" tangbands in each a pillar.
3 peerless 6.5s in each door.
Both are ran by a us amps ax4300
Then I have 1 8" b&c midbass in each door ran off a Rockford 800.2
Yall can't drive with your knee???? I used to roll blunts and drive at the same time while I was drifting //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Nice vid
16
You definitely need to re-tune the amp after changing the source (headunit). If the headunit in the new vehicle is putting out a lower RCA voltage...
888
Might not even be an issue if you don't have any really big panels on it. Otherwise dowels or threaded rod across your wide panels would be the...
18
2loud4youmorris
2loud4youmorris
Caro, Michigan
AQHDC3
    May 20, 2024
    May 20, 2024
