Sundown sd-2 10 sub
  • 4
The impedance doesn't determine how much power the sub can take. You need to determine what ohm load your amp makes the most power at and use that to choose a voice coil configuration. SD-2s can take anywhere from 400-500 eassyyy.
No I got that, sry for the confusion, my fault...amp is rms 500 at 2 and 900 at 1. Heard sd-2 can take more than rated, just need to know how much more to decide which way to go. Again thanks for the help.
If u can get a clean unclipped 900w then it will handle it but if I were you I would wire it to 1ohm and set the amp to only send the sub 750w that way you know the amp isn't clipping
RDS Audio 6.5. He is making me a 1000 watt 8 with 23 mm of xmax also. Should be done next week. I built a box in trade for some cash and a box...
8
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
593
ScreaminChicken
ScreaminChicken
Ky
jasonbillnelson
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
