How to fix a shifted motor?
  • 4
cooper1123
I bought 4 sundown e 12s and I have them installed in a 02 Silverado. They are all D4s, wired at 0.5 ohm. I was playing them and one rattled really loud and froze. I looked as if the coil had been welded to the motor and was seized up. I cut the soft parts out and the coil was perfectly fine. I looked closely at the inside of the motor and the gap was not even all the way around. It was like the slug in the center had shifted over and it will not move back. How do I fix this, who can fix this, and how does this happen? Any info would be helpful. Thanks.
I believe splaudio can fix them, not sure if its worth sending to get repaired and sent back rather than just buy another one.
I already bought another one, just looking to fix this one and use it as a spare. Thanks.
---------- Post added at 09:15 PM ---------- Previous post was at 09:14 PM ----------
i sure can fix and even build back to stock
Would ya mind sending me a price quote? Thanks.
So is the radio harness spliced direct to the OEM harness? There is no adapter harness?
12
Nothing wrong with the system. humming sound. Just the amplifier. Just switch it to volume maximum, then enjoy the music there. Loud. Sorry...
12
Sounds like an issue with the programming in your head unit. The designers didn't anticipate the day where the head unit would need to read 700...
So a hard-reset seemed to reduce the frequency of the issue, but it didn't go away. In fact, I can re-create it repeatably by going through...
cooper1123
cooper1123
Springfield, Ohio
cooper1123
