Subwoofer has no sound, but amp has power.
StrangeThrone
So, I have a 2009 Acura TL technology package and decided to put in an aftermarket 12" subwoofer but since I'm keeping the factory head unit, I bought a loc and wired it to my rear deck speakers L and R but when I play music the subwoofer doesn't have any sound, but it has power and has a good ground (area is sanded down and held with washer and bolt. Every wire is connected such as RCA to Line Output Converter RCA, left speaker wire with left speaker, right speaker wiring with right speaker, LOC positive 12+V is connected together with Battery on Amp, LOC ground with ground, speaker wire is connected from amp to subwoofer, and the LOC remote is connected to the amp's Rem. I don't know if maybe I have to tap into my fuse to for the remote, but can i get any help? The speaker is a 12" kit from SKAR SDR, amp is RP-800.1D
It sounds like a setting on the headunit. Turn the subwoofer level up to max on the HU. That might solve your issue. Do you have a subwoofer option on/off on your HU? That little selection is often the problem.
I don't think I do it's a skar 12" subwoofer, but it only has the obvious speaker wires and that's all. After work I'll go and check to make sure though. Thank you!
Turn the leveling knobs on your loc all the way up and then all the way down to the minimum setting. That type of loc is super sensitive. I went with a kicker brand after using that exact 1 on my Tahoe and the kicker 1 is way better and has very little to no distortion at all.
Check your remote line or RCA, some decks have written remote 2 times different wires one solid blue one blue and white, some do the misstake using the wrong one
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
772
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
StrangeThrone
StrangeThrone
Houston
Orionsundown
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
