sub recommendation for ported 1.25 cu ft @ 35 hz
kerpit
I built a box that is 1.25 cu ft tuned to 32 hz for my boat. I specifically built it for a dc level 3 12 sub. I did not know that with shipping it was going to take over 3 weeks for dc to build the sub. I have a trip planned may 14th and want a sub for this box! I'm searching for a used dc level 3 12 currently and haven't found anything yet. Is there another sub that would work in this box? I really want to stick with a 12 and $350 max. I will be powering it at 1k watts rms @ 1 ohm. I have found a level 2 12 and a level 4 12. But I think the level 4 needs 1.5 cu feet...
Any help would be greatly appreciated!
thank you for your time
Brian
I'd like to stay with a 12 if possible because I cut the **** hole already!!! Lol. Would a sundown sa12 just sound horrible in that small of a box if ran on 1k watts?
A ten(10) would perform so much better in that enclosure than a 12 in my opinion.You are limiting yourself on finding a 12 that will perform at its best with that small of an enclosure.Id recommend on making a baffle and cutting the hole out for a 10(Its just a sheet of wood placed over the existing cut out?Carpet it or?).You will have many more options and better output/performance.Open up your options instead of limiting them..Hell, a pair of 8s will get down in that enclosure
roger that, just got one from sonic electronix for $189. thanks for the help
18
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
206
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
542
kerpit
kerpit
Geneva,Il
Jeffdachef
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
