Sub problem
  • 4
rharlow83
The other day my sub just quit as i was driving. At first I thought my amp had overheated, as it has done before, but after being parked fr several hours still nothing so i started checking all my fuses, then wires and everything is good. Now i have noticed that the sub will still hit if I press in on the cone. I pulled the sub out of the box and was checking for any discoloration or anything that ight indicate a burnt out voice coil but everything appears fine. So what im wondering is. What is the problem and is it something i can fix? Or am i going to have to replace the sub?
sounds like you broke either a tinsel lead, or it's connection to the coil, or a portion of the coil leads on the cone, if it goes up to the cone and connects under the dustcap. not knowing your abilities, nor the sub in question, i'm not sure if you would be able to fix it yourself. a pic of the sub where the tinsel leads are going to the cone, and dustcap would help.
Measure the subs impedance see if u still get a coil reading. Could be the coil or tinsel lead as stated. U could possibly repair the tinsel if broke or have it reconed if r2 he subs worth the money.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
829
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
744
That does sound similar to what mine does, I'll take a video and post it this weekend so you guys can weigh in.
23
5K
198
rharlow83
rharlow83
st. Louis, mo
Robert 2001
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
