SSA Xcon 15 New Build
yahhhyahhh
Thinking of doing a build in my explorer with 2 SSA Xcon 15s in a 10cf enclosure @32hrtz on a taramps hd8000 with 2 xspower 3100 and a 270 amp alt. Can i get opinions on this any recommendations will be considered.
Kenwood X301& Sundown E-15 v3 5.8 CF Ported @34hz on PPI ICE2600
No first hand with Tara. Based on secondhand, im still leery.
I will throw out the Brutal Sounds 5k for a korean option. 799 right now
5k should power the xcons good?
---------- Post added at 02:09 AM ---------- Previous post was at 02:09 AM ----------
ND is 10 cf too much space for 15s?
Ssa says 4cu optimal. I had mine in 4.3 @29 and it crushed low frequencies. Power was a dd m3 @1 which it handled fine
i tried to talk him into ts 2.8k and 2 ts 15"s,, don't u think that would best nice setup? no info on subs that i've seen but sure look nice..
The xcon is in a whole different leauge than the ts subs. The tsx are certainly capable drivers. But they are a 2.5" coil, and probably shouldnt be considered if op is truly planning 5k+.
If he wanted to go smaller, than sure, the tsx 15s are a good option
I just checked out that Brutal Sounds 5K... how long has they been around?.. any issues you know of?.. Price is nice... .5 ohm capable with strong electrical... correct?.. how much electrical do you recommend to support 2 strapped into 1 ohm?.. just thinking out loud here... maybe next year...
What kind of music do you listen to? I'm a fan of SSA's subs quite a bit. Everyone I designed for really liked their SSA's, and I do like their...
14
I picked up a couple 12's for my civic. Figured I would hook someone up on here. Not trying to nab business, just trying to turn it around for the...
4
Evils are made to order, but the lead time is VERY short.
13
From their website. Sealed: 0.8 – 1.1 cubes Ported: 1.75 – 2.1 cubes ported after displacement, 29-33hz tuning Sub Outside Diameter 12.500" Cut...
yahhhyahhh
yahhhyahhh
Miami, Florida
yahhhyahhh
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
