Speakers for a 2006 Volkswagon Jetta
sabercat7
Hello everyone,
I have a 2006 Volkswagon Jetta, I would like to replace the speakers in it without breaking the budget, what I have is a seperate tweeter, woofer and mid-range in each door and 2 speakers in the back, I'm not sure how those are set up. I was told to put JBL's in the doors using seperate components and to put Boston Acoutics in the rear. I don't plan on changing the head unit. Would that be a good choice ???????????????
Thanks
yes more info needed, you have components in the front and coaxials in the back, and components should be amped
maybe he can use a LOC so he can keep the factory HU and just get a 4ch amp for the speakers, unless he already has a factory amp, dont those need to be bi-passed too?
and whats your budget??
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
297
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
224
sabercat7
sabercat7
Michigan
southwest713
Decebal
    Jun 10, 2024
