Speaker and amp combination advice please
  • 4
RussellJ
CarAudio.com Newbie
9
Dubai
Hello! I am new to the world of car audio! And I just want to ask if the following setup is wise/works at all without damaging anything! Be kind, as I may have jumped the gun with excitement and bought the wrong peripherals. But wanted to see if you guys think this will be fine to set up or a big no-no.
HU: Already exists in the car (Toyota GT86/FRS/BRZ) Sony XAV-AX1000
https://www.crutchfield.com/p_158XAV1000/Sony-XAV-AX1000.html
___________
Amp 1: Pioneer 1000w GM-A6704 - 4-channel 60 watts RMS x 4
https://www.crutchfield.com/p_130GMA6704/Pioneer-GM-A6704.html
Speakers Front (Doors): Memphis Audio PRX602 Power Reference Series 6-1/2" 2-way car speakers 50 watts RMS (100 watts peak power)
https://www.crutchfield.com/p_953PRX602/Memphis-Audio-PRX602.html
Speakers Rear: Memphis Audio PRX4 Power Reference Series 4" 2-way car speakers 20 watts RMS (40 watts peak power)
https://www.crutchfield.com/p_953PRX4/Memphis-Audio-PRX4.html
____________
Amp 2 (Sub): Pioneer GM-A3702 2-channel car amplifier - 60 watts RMS x 2 at 4 ohms (95 watts RMS x 2 at 2 ohms)
190 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode)
https://www.crutchfield.com/p_130GMA3702/Pioneer-GM-A3702.html
Subwoofer: Kicker 48TCWRT672 - 2 ohm 150 watts RMS (300 watts peak power)
https://www.crutchfield.com/p_20648TT672/Kicker-48TCWRT672.html
____________
I've highlighted the power ratings. My worry is that the amps are too powerful for the speakers. I've done some maths (I think) and I could be overpowering my speakers.
Advice would be much appreciated.
Thanks and I hope you're all doing well!
J.
Thanks, Bobbytwonames. Will try that when I get to the build. Would I still be able to balance correctly from the HU when it's powering a pair and the others are connected through RCA?
If I went down the original route; amp power would be fine on these speakers?
Thanks,
J
Thanks,
J
If you go the other route then just buy a mono (one channel) amp for the sub.
Not too much power.
You could buy very powerful amps and turn the gain down as well. It's way safer to have too much power than not enough. We are all big fans of 'headroom'.
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
545
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
464
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
You tried the external relay with no success? If so, how did you wire it?
18
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
RussellJ
CarAudio.com Newbie
RussellJ
Dubai
KicktheSDbasshead
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
