Running 2 amps off factory HU
  • 4
Silver
Brighton, MI
I have a ALPINE MRP-240 and a Rockford T-1000bd w/ 2 audioque sdc 2.5' 15's I want to run off my factory Headunit.
I have a 2007 Jeep GC with the premium sound (Boston acoustics).
I was thinking about getting the AudioControl LC6i, because I need 3 preouts (R,L on component amp, pre out for sub).
My plan is to get rid of the factory amp and speakers and run all new stuff. I just want to maintain my factory HU, I like the look.
So is a AudioControl LC6i worth it or is there something more efficient than that. Thanks.
I hope you understand that you won't be completely getting rid of your amp, you're simply re-routing the signal so that you can have pre-outs. Those factory amplifiers usually have more than just speakers inputs and outputs wired into them. The LC6i would be a good option (they have their ground loop problems at times though), or one like the JL Audio Clean Sweep.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
586
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Silver
Silver
Brighton, MI
MutantDreams
    May 24, 2024
    May 23, 2024
