Rockford Fosgate T10001bd Class D Amp
rfmayhem
audio4life
838
near your
Specs:
500 W x 1 @ 4 Ohms RMS
750 W x 1 @ 2 Ohms RMS
1000 W x 1 @ 1 Ohms RMS
Total power 1000 Watts
Bridgeable: Master Sync, Power Sync, (bd-sync2)
Crossover: LP 32-250Hz 24dB per Octave, Subsonic Filter 28Hz
Tone controls: Bass Control, 0 to 18 dB @ 35-70 Hz
Signal input: Low level - , Quantity - 1, Type - RCA(pr)
Line output: 1 RCA(pr)
Phase control: 0/180 degrees
Power input: Connector - Block, Wire gauge - 1/0 AWG
Speaker output: Block
Heatsink: Type -Cast, Cooling -Fan Cooled
Remote control: Included, Type - Wired, Controls - Bass
Class B/D
Dimensions 2.6 X 12.8 X 18 (inches)
$250 obo
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). "][/url]
"][/url]
"][/url]
"][/url]
is that a sheet metal screw holding the shroud on?
---------- Post added at 12:28 PM ---------- Previous post was at 12:27 PM ----------
nm, looks like a pc case screw
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
rfmayhem
audio4life
rfmayhem
near your
rfmayhem
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
