Rockford Fosgate RFR 3110 Rebuild
Grimmjoww
This is one of 4 subs I used to run in the early 2000's. This one ended up dead after being ran on a 1500 bd by itself lol. Man it rocked for a while though. The failure was a burnt lead. This is my first ever sub rebuild after being coached by DJ on here. I am very mechanically inclined as I am a pipe welder and build my own rock crawlers. But this stuff is very intricate and has been a challenging so far but completely doable with patience and measuring 3 times cut once type of things lol. Here are my pics so far. Waiting on my spring clamps from Amazon so I can't finish it out. I have the drop in built out and solid, shims were always used even on just the mockup, I didn't want anything binding. I cut the cone just a hair big so it slipped over easy so not to push the VC around. Anyways here yah go.
A few more
Did you measure winding width, divide it by two, plus half the top plate thickness, and mark the coil and line that up with the top plate 🤔🤔
The old spider was sagging very bad, after I took the measurements it made it more evident. The landing where the old spider is glued to the coil is accurate, but the outside edge has almost 5/8" of sag in it.
Older subs with poly cotton spiders all do that with time. Make sure all the joints you aren’t cheap with the glue! Thin layers built up and after each bead you do I like to wait about 20 seconds for everything to penetrate and then use the accelerator.
Dang your bead looks smooth lol. I did wait 20 seconds then used accelerator. I put 3 lights coats above and below the spider to coil and cone to coil. I should have enough left for 4 good coats on the spider to basket. The I stuill have a fresh tube or the rubber cement. Should I use the rubber cement on the dust cap to?
Do NOT use the ca glue on the dust cap. What rubber cement did you get?
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Grimmjoww
Grimmjoww
Tennessee
maylar
    Jun 2, 2024
    Jun 1, 2024
