Rockford Fosgate PRIME R150-2 power 2 10" p1?
  • 3
neither, run the P1's off of the Punch P300. you will be underpowering the P1's and P2's with those amps. That P300 matches up perfectly with the P1's
x2
The P300 is going to be 300w at 2ohms. The P1s are 150w rms, if I am not mistaken. They can take it as long as you don't get happy with the gain. More than anything, I have run numerous RF amps, but never anything from their new Prime series. The punch amps are not so expensive that they are out of reach, so I would stay away from the value line if at all possible.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Gatormjm08
Gatormjm08
St. Petersburg
Slammer
Decebal
    Jun 10, 2024
