Rockford Fosgate 2004/05 model P4004 4 ch amp
  • 2
beatnbronco
Item(s) for Sale: Rockford Fosgate 2004/05 model P4004 4 ch amp
Item(s) Description/Condition: some fine scratches and a few scuffs on chrome caps and missing 4 screws that hold on the chrome caps. Scuffs and scratches can be buffed out. Function is outstanding and comes with punch bass cable and knob
Price: $120 or best offer shipped in CONUS
Shipping and Miscellaneous Item Information: shipping included in price
back up for sale..here are specs..
CEA-2006 Compliant
Number of Channels 4
Rated Power
(RMS Continuous Power)
50 Watts x 4 @ 4-Ohms
100 Watts x 4 @ 2-Ohms
200 Watts x 2 @ 4-Ohms Bridged
Total Power
(Sum of Rated Power)
400 Watts
Bridgeable
Yes
Crossover Controls
High-Pass (HP): 40-400Hz 12dB/octave Butterworth
Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
Tone Controls
Bass: 0dB to +18dB @ 45Hz
Signal Input
Low level: 2 RCA pair
Input switch: 2/4 ch.
Signal Output
Low level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge
8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls: Punch Bass EQ (included with cable)
Visual Indicators
Power On
Signal Level
Thermal Status
Speaker Protection
Circuit Topology Class
Class A/B
Frequency Response
20Hz to 20kHz +/- 0.5 dB
Shipping Weight
17.5 Lbs.
(7.9 Kg.)
Dimensions (HxWxL)
2.4 x 11 x 16.4 (in)
6.1 x 27.9 x 41.6 (cm)
---------- Post added at 12:02 PM ---------- Previous post was at 12:02 PM ----------
here's more if needed
Rockford Fosgate® - P4004
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
beatnbronco
beatnbronco
Columbus, GA
beatnbronco
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
