rockford bd1001 2002 version would like to get $200 for this thing!
500 watts RMS x 1 at 4 ohms
1000 watts RMS x 1 at 2 ohms
Class bd technology
requires 4-gauge power and ground leads and a 100-amp fuse
selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise
preamp outputs for easy connection to a second amplifier
wired remote control of Punch Bass (0-18 dB centered at 45 Hz) gives you fingertip control of your bass impact
bd Sync allows you to bridge together two separate Rockford Fosgate amps
subsonic filter removes frequencies below 20 Hz for increased efficiency
13-1/8"W x 2-3/8"H x 9-7/8"D
Class bd technology
