RF Power T10001.bd amp
georgemra
1 - Rockford Fosgate Power T10001.bd mono block amp
Amp works great but has some scratches in the paint. Again, this amp functions great.
500W RMS @ 4ohms
750W RMS @ 2ohms
1000W RMS @ 1ohm
These are sandbagged ratings. The amp's birth certificate said it put out over 2300W at 1ohm (don't have the BC anymore).
$250 + shipping OBO
Shipping is on you. Probably going to run $15 - $25.
https://lh5.googleusercontent.com/-W62FBBsAhPM/Tjn60PcHvwI/AAAAAAAAAhs/ma3y_doXLLI/s288/amp1.jpg
https://lh5.googleusercontent.com/-sUkaqCr0TpM/Tjn6z5qsCeI/AAAAAAAAAho/yYjCs-jdyh0/s288/amp2.jpg
https://lh6.googleusercontent.com/-T8a1U2sLpM4/Tjn60W0PGTI/AAAAAAAAAhw/pFxC2Pp223Y/s288/amp3.jpg
https://lh4.googleusercontent.com/-ZjDDYcv4DHI/Tjn61IFaRmI/AAAAAAAAAh0/GRSsKJW3vwU/s288/amp4.jpg
It has a 28Hz infrasonic filter to prevent low frequencies (below hearing range) from being sent to the sub. So, yes it does have one built in just under a different name.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
469
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
697
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
510
georgemra
georgemra
Ann Arbor, MI
georgemra
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
