Re-wiring a car
  • 6
MoZ
So My jeep has a stock amp and the amp is kinda dying. I talked to the local car audio shop and they said that they could bypass the amp and re-wire the car from the head-unit. So i was wondering if that would be better just re-wire the whole thing from the deck or buy another amp for a little more power?
Right now i have 4 6" DS Kicker speakers and a Sony head-unit.
If I do re-wire it, what kind of wire would be good?
Rewiring the speakers to be powered bu the HU would be cheaper, but would result in lower quality sound (most likely). Buying an aftermarket amp would be more expensive but would result in better sound (most likely). It depends how much money you want to spend.
You can use any wire, it's all the same. Just find some speaker wire on crutchfield or sonicelectronix or something.
Yeah, i wish it was nice but its a 96 and i figure the HU would give out more power than the stock infinity amp?
What amp would be good around $150 for 4 6" kicker DS speakers?
MRP-F300 Alpine. The unbreakable amp. If it is a 96, you can just bypass the amp under the rear seat. The radio has hi level output to the amp. It will work just fine.
460
If the original plugs have been cut off, you may want to get some from a wrecked car. You could also search online for a radio pin-out for said model.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
223
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
290
MoZ
MoZ
Salt Lake City, UT
Imtjnotu
    May 23, 2024
SPLBassJunkie
    May 21, 2024
