RE SE or Kicker CVX?
if you ordered 4 of them, then I hope you have at least 3600-4800 watts on tap. I have owned one and they do get loud but they don't even play to their potential until you feed them about 1200 watts a piece.
763
SilverSquared
Fat guy on the GROUND.
SilverSquared
Southeast Louisiana
Lakota
    May 24, 2024
    May 23, 2024
