Precision Power P900.4 145W x 4, 4 available
trumpet
Barry Schanz
NIB
Sourced from a PPI authorized distributor. NO refurbished, B-stock, used etc.
RMS power 4 Ohms(14.4V) 145W x 4
RMS power 2 Ohms(14.4V) 225W x 4
RMS power 4 Ohms Bridged(14.4V) 450W x 2
RMS power 4 Ohms(12.0V) 100W x 4
RMS power 2 Ohms(12.0V) 150W x 4
RMS power 4 Ohms Bridged(12.0V) 300W x 2
Additional Technical Specifications:
Class D Full Range SMT Circuitry
Double Sided Composite Epoxy PCB
102 dB Signal-to-Noise Ratio
114 damping factor
32 dB Stereo Channel Separation
200 mV – 6V Input Sensitivity
Input Impedance 3.3k Ohm
20-4kHz 12 dB High Pass Crossover
50-5kHz 12 dB Low Pass Crossover
Source Input Selector
Three-Way Protection Circuitry
Delayed On/Off Circuit
Tri-Mode Capable
Band-Pass Crossovers
Direct wire 8ga. power & speaker terminals
0ga Reducer Terminal Included
Dimensions:
6.5″ W x 10.6″ L x 2″ H
$219.95 with free UPS ground shipping
PayPal, Visa/Mastercard/Discover by phone
order 24/7 at 6.5 Subwoofer, Buy 6.5 Subwoofers from Easy Way Electronics
Free UPS Ground shipping to the continental US
worldwide shipping is available
USPS, Fedex
I got one P900.4 returned. I tested it on my bench today for several hours on some 4 Ohm cabinet speakers. I would make a special deal on this amp only.
The reason for the return was the customer discovered the amp lacks an RCA pass-through output after he opened the package. I have to check operation of an open box return. I'm offering $180 shipped for this particular returned amp only.
How are you having trouble selling these? Perform at rated or sometimes more and clear as a bell, plus tiny (though not as small as the nano bits).
Smh...
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
501
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
713
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
