Power Acoustic 2500 only blows 1fuse
  • 3
need more information. Go into detail of how it's blowing a fuse, like under what conditions? While playing? As soon as you put in the fuse? Something else?
probably got the gain turned waaay up. Also remember this is just a 2 ohm stable amp. Make sure your subs are wired for a 2 ohm load on the amp. Their website says it is capable of 650watts rms at 2 ohms, which may be truthful, I don't know, power acoustik is a known liar about their power ratings.
Might want to search up how to use a multimeter to set gains on a monoblock amp on youtube.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
556
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
739
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
563
twistedmister80
CarAudio.com Newbie
twistedmister80
Beatin'
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
