Pontiac G8 Audio Upgrade
bobmG8
I am currently planning my Pontiac G8 Audio Upgrade. Door speakers with two sets of Polk Audio db651s. I have purchased an MTX re-Q5 processor. The Alpine 3553 4 x 35 will power the door speakers and the PPI PC275 2 x 75 will power the new Bazooka BT6024DVC passive sub which has a dual voice coil. I am mounting the amps and processor to the underside of the rear deck in the trunk. Including the processor and sub all I needed to purchase was some speaker wire, 3 short RCA cables, shrink tubing, screws and terminals all for around $300.00. I will include pictures during the install process.
I removed the details for the texting generation. My first car stereo installation was back in 1974, the car was a rusted out Chevy Vega that I bought for $300.00, the car not the sound system. I will blame the book on my advanced years.
Amp install looks good but amps mounted upside down are a no no. There is a reason manufacturers put the heatsink on the top of the amp as opposed to the bottom. Sure plenty of people have done it but having repaired quite a few amps I can already see the capacitors and output/power supply devices inside just baking away from the heat trapped inside the amp.
I asked about mounting my amps upside down in the Amplifier forum and I was treated like an idiot for asking. BigAudioFanatic wrote: Your amps will be fine, you might have heat travel in the wrong direction inside them because they are upside down but no reason why you can not. I also belong to g8board.com and a guy mounted his amps in the same location so I asked him if he had any heat issues down in Miami and he said his amps were working just fine. If there is an issue with this set up I will remount them in a different location. Thanks for the input.
Thread: Mounting Amps Upside Down??
I know most people won't take issue with how you mounted them but I've just seen too many amps with signs of heat related stress( baked caps,melted solder,etc) to feel good about mounting them upside down. I'll probably get flamed for my opinion as well.
Well I finally finished the work in the trunk on this sound system. All I have left is to splice into the radio speaker wires.
MTX re-Q5 Processsor
Alpine 3553 4 channel Amp
PPI PC275 2 channel Amp
Bazooka 6.5" dual voice coil passive sub
(4) Polk db651s in the doors
4 Ohm 10 Watt resistor for the front/center speaker
Monster RCA patch cables
picture.php
I finally finished my install, and the MTX re-Q5 bass restoration device worked very well. Actually amazing on how well it interfaced with my base G8 radio. The 6.5" DVC passive tube provides just enough tight bass to complament my Polk speakers to produce a rich sound. I did remove the stock tweeters in corners of the dash which helped. Overall this is a huge impovement over my stock system.
A Link would be very helpful. Id be interested in taking a look at some gear
197
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
324
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
bobmG8
bobmG8
Milford, MI
bobmG8
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
