PLEASE HELP!!
  • 4
hossk24
CarAudio.com Newbie
I have an Alpine 143-BT head unit that has decided not to work. When I put power to it you can hear the eject mechanism inside making noise (CD eject mechanism). Nothing lights up on faceplate. How could you determine whether or not it is the faceplate or the actual head unit itself that is the problem?
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
hossk24
CarAudio.com Newbie
hossk24
Three Forks Montana
hossk24
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
