bigp0ppa1046 10+ year member
Ok guys, I am fairly new to the car stereo game. I have put a few in my cars and in other peoples cars and they have sounded pretty good but I have never really paid any attention to what i was actually installing, as to the specifications of the equipment.
Right now I have a Kenwood KAC-9103D
Here are the spec:
* RMS Power Range : 500-900 Watts
* Number Of Channels: 1
* Maximum Power: 1800 Watts
* Low Frequency response: 20 Hz
* High Frequency Response: 20000 Hz
* Built In Crossovers: Yes
* Channel Separation: Yes
Features
* RMS Power @ 4 ohms: 500 Watts x 1
* RMS Power @ 2 ohms: 900 Watts x 1
* CEA-2006 compliant
* Top-Mounted controls
* Preamp Outputs - 1 Pair
* Power MOSFET Switching Power Supply
* Variable Low-Pass Filter: 50 - 200 Hz
* Infrasonic Filter: Off / 15 / 25 Hz
* High- and Low- Level Input
* Adjustable Input Sensitivity: 0.2 - 5V
* Bass Boost Control: 0 - 18 dB
* Class D Amplifier Circuit
* RCA Inputs/Outputs
* Fuse Rating: 30A x 2
* Signal-to-Noise Ratio: 94 db
* Dimensions: 11-1/4" L x 14-15/16" W x 2-9/16" H
Now I was looking at the Pioneer Premier TS-W3001D2 or D4 sub, but i dont know which one to get. The specs for both subs are identical except the OHMS. I was wondering if someone can help me with which on to get and why?
Specs:
* 12" Champion Series Pro
* Woofer Cone Material : Interlaced Carbon Fiber/Glass Fiber Reinforced
* Surround : Wide-Roll, 3-Layer Fiber Woven Aramid Radial with Honeycomb Cloth
* Voice Coil : Dual 4-Layer, Long Voice Coil
* Voice Coil Wire : Copper
* Voice Coil Bobbin : Phenol Resin Coated Glass Cloth
* Projected Pole Yoke with Vented Pole
* Magnet : Double Stacked 110oz
* Aluminum Die-Cast Rigid Chassis
* Gasket 1-Piece Rubber
* Integrated Single-Sided Silver Compression Terminals
* Max Power : 3000 Watts
* Nominal Power Handling : 1000 Watts
* Frequency Response : 18Hz~700Hz
* Sensitivity : 89 dB
* 2-Ohms Impedance (D2) or 4-Ohms (D4)
* Recommended Enclosure Size : 0.50~1.0 Cubic Ft
* Mounting Depth : 7.5"
* Approximate Weight : 27 LBS
Here are the spec:
Features
Specs:
