Please help!!! Whats wrong with my install?
  • 2
holder14
I am installing my new alpine pdx-f4 in my 2001 jeep grand cherokee. I have all the wiring set up and running to my speakers. I have one set of eclipse 6x9's and a set of alpine type r 5.25 components. When i turn on my head unit i get a loud thumping/pounding sound coming from the speaker(check vid). It only comes from the speaker hooked up to the first channel no matter which speaker it is. What did i do wrong?
Is it the ground, even though i have tried a couple different grounds?
What is yours thoughts.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
holder14
holder14
Aberdeen, SD
LosIsATool
